Water Tank Hatches General Forum Forums
Water Tank Hatches
November 8, 2019 - 1:14 pm
I finally got my water tank hatches installed.  Seems to be more economical than removing the tanks and replacing.  Inside they came out pretty clean.
https://imgur.com/a/tBMERIj
Leo Uhran
Port St Lucie Fla
November 12, 2019 - 6:44 am
Forum Posts: 42
Patrick,
So if I understand, you installed access hatches into the top of your existing water tanks large enough to access the interior for making repairs? I tried the link but can't access any photos.
My forward tank has a really slow drip leak and I have ceased using it entirely until I can figure out a game plan to fix or replace. My thoughts were to remove both tanks entirely cut/extend (join) the hatches as one long access hatch and replace with a single long rectangle polyethylene tank as large as I can fit into the opening. It would  reduce the total gallons a bit but that would be fine by me.
The previous owner new of this problem had used some kind of food grade sealant that was applied to the interior walls and corners of the tanks. This seemed to work for him for about 5 years up to the point of me taking ownership.
Leo
SV Paper Moon
Hull 136
November 13, 2019 - 12:04 pm
Cool. Are those Lexan plates? Are we seeing through to the inside of the tanks in that pic?
Also, can you say where the baffles are in those tanks? I seem to recall someone saying that they issues installing access plates because of the baffle locations.
November 13, 2019 - 1:18 pm
Here's a picture.  Yes it's polycarbonate sheet to cover the hatches.  I want to velcro a UV shield on top of them for good measure.  I also am not sure if the sheet is strong enough so I have some UHMW sheets I can swap out that are a little thicker.9xwUTDY.jpgImage Enlarger
James Handzus
New Member
March 9, 1924 - 3:16 pm
Forum Posts: 1
That is a really good idea! I love this site and thanks for the idea.
Treenut
Holland, Michigan
March 16, 2020 - 11:38 am
Forum Posts: 8
Might I ask what you used to cut the stainless steel?  It seems to be quite thick, at least 2 MM
