Icebox Capacity of DE38 General Forum Forums
July 17, 2016 - 11:01 pm
 I'm shopping for refrigerator units to replace the antiquated Peltier-style units that came with the boat.  I was curious if anybody happened to know what size the iceboxes are in the DE38.
July 18, 2016 - 9:22 am
I don't think that we have that information on the site. I could be wrong but a quick search didn't find it. 🙂 time for the tape measure and to let us know how many cubic feet the aft one and the ones beside the sink are 🙂
I would estimate that the two big ones are about 5 or 6 cubic feet each while the little small are just beside the sink is maybe 1.5 cubic feet in size. Best guestimate just picturing them in my head..
anyone else have a guess? We can see who has the best eye for estimating when Patrick or someone else actually measures it and reports back.
July 18, 2016 - 12:30 pm
Two big ones? There's one forward of the stove, and one forward of the engine compartment.  I thought that space port of the sink was for dry storage.
July 20, 2016 - 4:42 pm
I don't think any one actually knows that that hole in the counter next to the sink is for. I've seen threads on it and it's a headscratcher. I think that's what happens when you have space and no good idea how to use it.
I'm thinking it's going to be a trash can or more likely, dry storage.
And I'm not even sure the one forward of the stove has much insulation. Scott, do you put ice in that one and does it stay cold at all? I'm told you need 4" of closed cell insulation but I think that one has about 1" if anything.
I'm not expecting to keep ice cream, let's put it that way.
July 20, 2016 - 6:02 pm
hmmm . we put a few pots, etc in that small hole next to the sink. when washing stuff if you sloshed over or dribbled it would get in there and just stand in the bottom. So anything that needed to be dry was out. if you didn't clean it out regularly it would mildew in there also.as a small trash container it has potential but it is small.
one outboard of that was totally covered in spray foam under the sink etc... not sure how deep. we never used it for anything but dry storage and that was just stupid stuff we didn't ever use. If I had more money than sense I would turn it into a freezer with its own compressor. I think some of the new water cooled units would make a huge difference in performance and power used. We covered the top of the existing refrigerator unit in a piece of mirrored bubble wrap stuff (reflectix) cut to the shape of the whole countertop back there. Sewed a piece of nice beige vinyl onto it as a top. It was always cold between that and the top of the fridge even with new seals in the fridge. But top of it stayed room temp. Figure it helped maintain temp a lot. Kept intending to install a j trap under the drain to keep cold air from flowing out if it. its small 1/2 inch or so but I'm sure that added up over time.
September 28, 1925 - 3:53 am
I am (again) looking at putting a refrigerator unit into the old ice box.
The installation seems straight forward enough, especially with You Tube videos to help.
My question here is the about the original ice box.  The sides are convex.  That is bowed out towards the inside.
At least that's how they are in my 1975 DE38.  Is that normal?  Seems pretty weird.
As insulation of the fridge is important I am wondering if I should cut out those old walls, put in new, better insulation, and replace the walls with something (not sure what).
Another point is drainage.  There is a tray at the bottom of the ice box with large holes to let melted water run into the drain to the bilge.
I would of course want to keep the drain open but that space could be used for food/drink storage.  Maybe that tray could be fitted lower down in the box.
Thoughts?  Comments?
Thanks in advance.
September 30, 1925 - 12:51 am
The sides should not be convex. sounds like foam insulation that expanded and warped the sides. No good ideas on fixing other than tearing out and replacing. More work than I would want to do... but   with convex sides im not sure how much space your losing or if it will affect installation of fridge equipment.
September 13, 2021 - 1:03 pm
On my DE38, built in 1975, The small space next to the double sink was made to hold a plastic bag for trash.  The cover is a teak and holy cutting board  and beneath the board is a removable s/s rod which holds the top of the plastic trash bag.  Works great.  Cheers,
September 14, 2021 - 12:07 pm
Thanks, Scott.  Volume is not a huge issue for me as we are only casual users of this boat, but for legacy it would be nice to get it right.
Maybe a little "plastic surgery" would work.  At least one side where the fridge coils are mounted would be nice to have plumb.
Never a dull moment, eh?
September 14, 2021 - 1:46 pm
Had a thought...... could work or could break it.... if your going to  pull it out to fix it then this would maybe be worth the risk..
take a couple pieces of 3/4 inch ply on either side inside the box on the bowed out sections.. put simple hydrolic jack between the two and see if you can push it flat. if it is expanding foam and not to dense you can probably crush it a little flatter behind the bowed out sections. Or you might break the liner in the box, or rip the whole box up 🙂 lol.. if you do it do it slowly and carefully.
September 16, 2021 - 12:58 pm
Interesting idea, Scott.
I'll have to find a small jack!
As you say, it's worth a shot!
Thanks.
