Perko Water Strainer Engines and Such Forums
November 20, 2013 - 11:19 pm
It says on the top "Open to Clean". when I started to loosen it, it started to gush water.
Do I need to close a seacock ? I don't have a manual for this device.
November 24, 2013 - 11:43 pm
If the strainer is located below the water line (and your boat is in the water) then yes, it would be a good idea to close the seacock before any opening it. It would be better to relocate the strainer to a point above the water line if possible.
A very basic set of instructions are available here:
"www.perko.com/search/strainer/page/1/"
-Argyle
December 4, 2013 - 6:00 pm
Our water strainer was like this. You did have to shut the seacock.
December 16, 2013 - 12:40 pm
Thanks. That worked. But I notice that the lid leaks just a tiny bit. Even though I've tightened it pretty tight. (The top wing nuts.) There's no gasket there. Should there be one?
December 16, 2013 - 6:01 pm
thats why we pulled ours... just havent gotten around to replacing or finding a gasket. Actually on ours it would sometimes pull air when the engine was running.
