OfflineFor some reason the original owner of my DE38 never had a boom vang. I think this is pretty essential for control of the mainsail, so am looking into the various options. What I see in the various suppliers is like a main sheet with double block on top and bottom with a cam cleat on the bottom block. The questions arise as to size of the blocks and the size of the line. Could someone please let me know what the configuration of original boom vang was and/or recommendations for alternatives which have worked for you? Many thanks in advance.
So, i would say 3/8 inch line and blocks that can stand a couple thousand pounds force.
to give an example here is a schaefer boom vang kit for our size boat
https://hardware.schaefermarine.com/index.php?main_page=index&cPath=147_128
The price on schaefers website is significantly more than on defender where I posted the first link.. however for some reason I could not get that link to post correctly so you will need to go to http://www.defender.com and just search for boom vang kit and then find it there.
I have purchased garhauer hardware for my boat and found it to be a fraction of the cost of the other name brands and absolutely stellar quality
here are some of their boom vang setups directly from them https://garhauermarine.com/catalog_process.cfm?cid=38 just look for the ones that have a 2800 lb working load. all of them are under 200 dollars ... they also have some decent bails.. Honestly I would give them a call and discuss your installation and what bail to use and how to attach it. I think that using screws to install it would not work well but that your going to need to get a bolt that goes through.. however all my boats already had it installed and I haven't taken one apart that I remember so I'm not going to be absolute about this. They have been very helpful over the phone when I called them before.
I think you could piece it together for a lot less than their price though. If you don't already have attachment points on mast and boom you need to figure in those.
OfflineScott. Would you mind re-posting that link to Defender? It did not work for me.
I think I know what you are looking at but just want to be sure. It looks like the Shaefer Series 7 blocks would be the right size. Agreed?
I am learning some new terms like fiddles and beckets! Interesting.
As to the bails, I am thinking that they should be screwed into the widest points on the boom/mast to get the screws in shear. If the mast were off the boat I could through bolt the bail, but since it is mounted on the deck I'll have to use self tapping screws. (or should I drill and tap larger ones
Comments/advice please.
I have re-edited my initial post to fix links.. for some reason the way defender makes links for the direct product I can not get it to save correctly. I just created a like to their website and you will have to search from there. I put in links to the products on the Schaefer website. While doing this I remembered Garhauer and looked on their site. You can purchase one of three different model boom vangs suitable for the DE38 from their website directly for 175 dollars. They make and sell directly their hardware and have incredible quality products. I have started to purchase their hardware more and more over the years and been impressed with it every time. The link to the boomvangs has been added to the original post I made.
OfflineI had the crazy thought during the night that maybe I should look for some old wooden blocks to make up the vang! All the other blocks on the boat are wood faced. Having several of these fancy new SS fiddle blocks might not look good! Of course one has to be sure of the strength of the "system" and with old blocks that might be nearly impossible (except by trial and error). Just a thought!
Cheers
OfflineMost Users Ever Online: 1263
