Toe/Top rail help for Wundorstar General Forum Forums
Wundor Star
September 18, 2017 - 1:06 pm
Forum Posts: 23
Hey everyone, I need ideas on my top rail. I got into resealing/bedding the fittings, and prep to paint, and discovered at least 8 major rot / damaged area that had been covered up with fill, then painted.
So, I do not think the majority of the rail can be saved, or at least I do not have that skill. Has anyone seen a replacement or source for it? And the next thought, should I go over to steel or aluminum rail? I like the look of the wood, but mine was painted by previous owner, now I realize why. And I do not think I can afford wood, and the boat wright to scarf it back in.
My major concerns are if I go to metal, the chain plates, and stanchion bases thru the metal.
Has anyone seen this project tackled, and has photos of the rail being in metal?
Thoughts, and I did see the post by windsong, which looked great. But my rail, at least the forward 2/3 is really in bad shape. Sort of upset with my self for not seeing it before...
Thanks, Travis
Travis and Kim
S/V WundorStar
DE 38 Ketch
September 18, 2017 - 1:29 pm
So if I ever had to do valkyrs I would find some IPE and use that. It is brazilian Ironwood. Relative of teak, it is harder and denser than teak.. It actually will not float in water. You will have to pre drill every hole for mounting etc.. so if you use it I would buy it and then one piece at a time remove the existing cap on the rail and use it as a templete to shape the IPE and drill your mounting holes in it. This stuff is used in really high end decks in the housing industry and cost's (or did last time I checked) about 1/5 what teak would. I think it will last twice as long as teak given how dense it is. Like I said though every hole needs to be pre-drilled as it will split and crack if you drive a nail or screw through it before drilling. Part of the price of the hard is that it is more brittle.
Tim Donley
November 26, 2018 - 9:16 pm
Forum Posts: 4
My cap rail is trashed from years of sanding and neglect. A lot of builders in the 70's used Afrormosia as a substitute for teak. Less expensive varnishes and looks like teak but not a weather resistant as teak. This cap rail appears similar to Afrormosia .
I am planning to look into  Ipe hardwood. When varnished it is as gorgeous as teak. Yes it is hard to work as it is very hard and will eat saw blades. This is my plan at present as the DE deserves the beauty of a new fair varnished toe rail. After the build up coats of varnish have cured (30-60 days) I plan to topcoat with Bristol Finish.
Work, work, work......Cool
November 28, 2018 - 8:47 am
I think IPE would be an excellent compromise. I have used it several times on my boats and it is very durable and really pretty. Granted it is a pain to work with, but compared to teak it is affordable.
December 16, 2018 - 12:03 pm
My cap rail is trashed too from yrs of sanding and being removed so the joint could be resealed.  Not to hijack your thread...but What's the trick to stopping the leaks? I been using life seal and it isn't working. I've added knees at the chain plates haven't leaked there yet. seems to leak where the lifelines open up. Keeps leaking there from trading on the rail there and I assume from using the stanchions as grab rails...I've been contemplating ripping off all the cap rail sanding and grinding and epoxy and a layer or 2 of glass I'd lay it over the through bolts and then over the outside maybe an inch to cover the joint sanding it smooth and painting..not the prettiest thing in the world but I could always add ipe toerail over it in the future. Stopping the leaks would be my first concern. Do I need something flexible there ( 5200? 4000?) OrOr would the glass and epoxy just crack? Not sure if this area needs some flexing .
P.s Scott I was looking at boom gallows designs and I saw your boat on another website used as an example. You do nice work I hope my de is as nice as yours some day.
December 16, 2018 - 7:14 pm
That's interesting... post a link to that about my boat if you remember where you saw it please. Lol ... I love my boat but she is in serious need of soap and water right now 🙂 maybe some varnish on the outside wood 🙂
We don't have many issues with leaks on valkyr.. not really my doing just haven't had many issues. propane locker is our biggest issue. every once in a while some gunk off deck gets in there and plugs up drain. Then locker fills up and leaks in around where propane hose goes from regulator,safety  valve to stove. Most most years we have owned the boat and she has sat at dock or anchor the bilges have been dry. Once in a while a deck drain or more problematically the propane locker drain gets blocked and water backs up till it finds a way in. Even then it is in ways and places that has not impacted the inside of the boat other than ending up in bilge. Biggest thing we did to help with this was a separate bilge box for chain lockers, ac condensate and shower up under deck in vberth. Oh we also get a bit of water in really heavy rain around glass in butterfly hatch amid ships. not enough to hurt anything under over the years. Every once in a while I take some capt something or the other creep and crack? mix and seal them up again.
December 17, 2018 - 4:46 am
You and brodham haha both fine boats since I don't have the money to buy brodham I'm trying g to duplicate her .
https://eoceanic.com/sailing/tips/35/300/help_to_keep_the_boom_under_control/?
December 17, 2018 - 7:18 am
so that is actually not Valkyr and the credit to me for the picture is misapplied as I didn't take it. It is probably something the author pulled from the downeaster website.
Hmm. did a little searching and it is possible it is a photographer in New South Whales named Scott Carle that took the photos. It seems more like it would come from our website given the DE's in the picture but the photos are also claimed to be licensed under a creative commons 1.0 and 2.0  license depending on the photo in that article and I have never used a creative commons license.
I do have a boom gallows arrangement but it is massively different than those shown in the article.
Here is the write up of my hard dodger project ( http://downeasteryachts.com/ar.....hives/3547 ). the boom gallows in integrated into aft end of the dodger about 24 inches forward of the trailing end. It is simply at raised aluminum tube bolted into the structure of the hard dodger frame that keeps the boom from hitting the top of the dodger. You can also use some heavy duty commercial bungee's to lock it down to the boom gallows anywhere along the length. Or you can use a piece of rope to tie it down centered where there is an upright you can use to keep it from having any port or starboard motion. Also the handrails on either side are strong enough that you could tie the boom to them also if you wanted it more outboard port or starboard. All the aluminum is 1 1/4 inch heavy wall marine grade aluminum. I designed the dodger and had a local guy fabricate it. He took my design and modified it to be stronger and prettier and turned it into a work of art as far as I am concerned. If you read the article in the link above you will see pictures where it shows the details of  bends and curves that make it stronger. I can grab a hand rail on this thing and with all 200 lbs of my weight yank on it as hard as I can. It will move the whole boat but the dodger wont flex or budge. You can safely use it to tie off to for a anchor point in bad weather etc as you work on the mid deck or as you go forward or aft on the side decks. It has articulated pads that secure it to the coach roof.
Here is a picture of the finished dodger showing the boom gallows. As you can see it is more of a modern interpretation of a boom gallows than reflective of a traditional one like seen in the article you referenced.
Boom Gallows on sv ValkyrImage Enlarger
here is a link to forum posts talking about our dodgers before and after the hard dodger
http://downeasteryachts.com/fo.....-for-de-38
