Solar Panels General Forum Forums
Solar Panels
January 6, 2011 - 2:35 pm
I just ran accross a really great deal on solar panels for anyone looking.. now I'm wishing I had waited to purchase. I thought I got a great deal when I bought mine.
http://www.sunelec.com in florida has high voltage 80 100 watt solar panels on sale for 1.19 per watt.. You would have to use one of the more expensive MPPT controllers with these panels but what a deal.
Sun Electronics Solar Panel 105 Watts SUN-DA105-A 1B
$124.95
Model SUN-DA105-A 1B
Power (W) 105 Watts
Open Circuit Voltage (V) 100 Voc
Short Circuit Current (A) 1.66 Isc
Maximum Power Voltage (V) 75 Vmp
Maximum Power Current (A) 1.40 Imp
Lenght 43.62" (1108mm)
Width 55.37" (1406mm)
Depth 1.37" (35mm)
Weight 44lb (20kg)
SUN-DA121
$143.99
Sun Solar Panel 90W 71.4V SUN-DA090-A 1B
$107.10
This Sun photovoltaic modules are designed and manufactured
using the cutting-edge amorphous siliconmicrocrystalline thin film
technology. With unique product features and
capabilities, they are able to provide ideal solution for rooftop
solar projects.
Model SUN-DA121
Power (W) 121 Watts
Open Circuit Voltage (V) 146.60 Voc
Short Circuit Current (A) 1.22 Isc
Maximum Power Voltage (V) 120.60 Vmp
Maximum Power Current (A) 0.99 Imp
Lenght 55.47" (1409 mm)
Width 43.70" (1110 mm)
Thick 1.37" (35 mm)
Weight 44.09lb (20 kg)
Sun Electronics Solar Panel 100 Watt SUN-DA100-A 1B
$119.00
Model SUN-DA090-A 1B
Power (W) 90 Watts
Open Circuit Voltage (V) 94.7 Voc
Short Circuit Current (A) 1.54 Isc
Maximum Power Voltage (V) 71.4 Vmp
Maximum Power Current (A) 1.26 Imp
Length 55.5" (1409.7 mm)
Width 43.7" (1109.98mm)
Thickness 1.4" (35.56 mm)
Sun Electronics 80 Watt Solar Panel SUN-DA080-A 1B
$95.20
Model SUN-DA100-A 1B
Power (W) 100 Watts
Open Circuit Voltage (V) 99.20 Voc
Short Circuit Current (A) 1.55 Isc
Maximum Power Voltage (V) 76.96 Vmp
Maximum Power Current (A) 1.30 Imp
Dimensions (L x W x T) 55 1/2" x 43 7/10" x 1 2/5"
Note: Item in stock in Phoenix, Arizona Only.
Model SUN-DA080-A 1B
Power (W) 80 Watts
Open Circuit Voltage (V) 100.00 Voc
Short Circuit Current (A) 1.62 Isc
Maximum Power Voltage (V) 71.00 Vmp
Maximum Power Current (A) 1.27 Imp
Lenght 55.5" (1409.7 mm)
Width 43.7" (1109.98 mm)
Deep 1.4" (35.56 mm)
8 Guest(s)
