Navigatrix Operating system General Forum Forums
December 2, 2010 - 4:05 pm
I recent ran accros this and downloaded and tested it out. It pretty much works as advertised. I thought some of you might be interested. It's free and can use the free map downloads from NOAA. You can also run it off a USB Stick if your computer can boot from one. So far I have tested the chartplotter with a gps connected and using NOAA ENC Vector Maps. I have also used the Gribb software to downoad and display weather maps. Here is the blurb from the website http://navigatrix.net
Navigatrix is a complete operating system for your computer. It is put together by people on boats for people on boats.
Navigatrix is a compilation of electronic tools for navigation, communication, information and security that you can use offshore, on shore, or at anchor. It is simple and lightweight and based on the latest Ubuntu has to offer.
Navigatrix is the fastest, most efficient, and versatile Linux distribution for cruisers and navigators available. It works on most any personal computer built in the last 12 years.
Navigatrix is nearly indestructible running on a 4 gigabyte, or larger, USB stick or SD card. It allows access to your hard drive data if you choose, and even works if your hard drive doesn't.
Navigatrix can also be installed on your hard drive for increased speed and versatility.
Download Navigatrix, install your charts, and test it out. You may find it is exactly what you've been seeking. Navigatrix is free to use and copy. If you have been charged, or you charge, more than a nominal copying fee it's not right.
I
