OfflineHello,
New member, 1st post, glad to be here! Hopefully I will be able to contribute at some point and I look forward to that day.
After much research, long trips to dock walk and visiting some prospective boats, I have made my mind up on a DE38. I was originally shopping for a W32 but after being in the cockpit of one I knew it was too small (the cockpit). Also, double enders are limited as far as being able to add arches for equipment. I started a thread on the CF forums asking for heavy displacement boats with a square transom. One of the responses was Downeast and after being on one I was sold.
I have now began looking in earnest at DE38s online and find that they are spread far and wide. Its going to be an expensive proposition to fly to these far flung marinas so I wish to get the most bang for my buck by knowing what to look for before I go and while Im there.
So, I am wondering if there are any questions I can ask a broker/owner that are specific to DE's in the front end before I schedule a trip?
And, if I do decide to visit the boat, is there anything specific to DE's to look for? The little things only DE owners know about that I can be sure to look for or pass on to a surveyor.
I thank you in advance for your replies!
Jim [Image Can Not Be Found]
Hmm.. the main gotchas specific to DE's that I would look at is deck delamination in general and under the mast in specific. Is the mast sinking into the deck.
Second would be the condition of the fuel and water tanks. Do they have any leaks. For fuel this would be pretty easy to determine as you would leak into the bilge but a little harder with the water tanks. These are a major job to repair. Though there are some good write ups on doing so. The big problems with the repair is that the installed the tanks and then installed the floor over them so you have to remove the floor to get to the tanks.
DE's tend to accumulate leaks around the cap rails and stanchions into the boat if they haven't been maintained. Sometimes this just goes straight to the bilge but sometimes it will impinge on the interior joinery.
other than that I'm coming up blank at the moment. I'm sure some of the other owners will have some things to look at for also.
other than stuff that is specific to DE's you still need to look at all the other issues such as blisters on the hull, rigging condition, rudder and rudder stock condition, bowsprit condition, engine condition, electrical and electronic systems etc. etc... a good surveyor is a great thing.. Harder to find than a good boat but still worth their weight in gold 🙂
OfflineJim,
All the usual stuff, like Scott mentioned but on the mast issue be sure to look under the sole from inside the Vberth at the 4x4 support for any sign of deterioation. I will show up in the area of the sole under the compression post.
Also, if it still has the wood bowsprit look for signs that the bowsprite is moving aft. The way I could tell is that the sampson posts started angling aft. They should be perpendicular to the sprit.
Happy Hunting,
OfflineThanks guys for the replies. So normal sailboat issues, nothing out of the ordinary.
I went to see one last weekend in Florida. Was really nice and I was impressed with the solid feel of the boat. Made an offer but the seller will not budge from his asking price so....the search continues!
Thanks again
OfflineCan anyone confirm that all of the DE 38's built with lead ballast Does anyone have any problems with the core material under the deck?The boat that I have now has marine plwood for the core and I havn't had any problems with it .Is it true that the nonsid is ground walnut shells? Any help will be appreciated ,I am looking at 1976 ketch.
Thanks , Marty
Thanks , Marty
Marty,
I have heard from owners that had lead and steel punchings in their keels if I remember right. Maybe someone else could speak up about this with more authority than me. I have never had need to cut my keel open. 🙂
The core is a common problem on these boats. Mine is foam core not plywood and we have had a decent amount of it re-cored. The faxtory did not core, back fill with epoxy and redrill mounting holes so if you got a leak around a deck fitting it would get into the core on deck. As we do thing s we have been drilling out and filling holes that are no longer used and coring and filling with epoxy and re-drilling mounting holes to fix this. My understanding is that other than a few high end boats almost all production boats of the various brands tended to cheap out and just drill through the coring without sealing it. If you deck is solid then thats a good thing. If you have plywood then either it has been re-cored or the switched to foam after 76... our boat is a 79.
The factory non-skid tended to be a paint with sand broadcast into it. let it dry and then brush off excess sand and then paint over it again. Very aggressive non skid that lasts forever. expect to lose skin if you skid on it 🙂 If your boat has ground walnut then it was a option at the factory or more likely it has been redone since then.
OfflineDepending on the year ,the DE's have different stanchions. I think some have flanges that bolt down and I am not sure how they are backed. Some stuff on my boat that are bolted through the deck have decent backing plates and other stuff just has washers. As I get to that stuff I change it out to decent backing plates. On Valkyr our 79 DE38 the stanchions have moulded fibreglass sockets that they slide down into. The sockets are moulded into the inboard side of the bulwarks. If the one your looking at does have bolt on stanchions then I would expect backing plates for sure if it is done right. You'll have to check though. It's amazing how many boats I have seen in general that don't have this.
Any one else that has worked on their stanchions that bolt on have any advice or knowledge they can pass on?
OfflineScott,
Thanks for the info. I'm trying to educate myself on these boats before I even make the trip to look at the boat.The boat I'm looking at is a 1976 38 ketch in Slidel Louisianna.It is listed on Yachtworld.This would be about a 7 hr drive for me .I trying to think of everything I might want to look for and ask about before showing up .If you get a chance take a look at the boat tell me what you think.I know most of the standard stuff to look for because I basicly rebuilt the boat I own now,but never having been on DE 38 Im sure there are some things I won't know to look for. Thanks for your help and comments.
Marty
I can't think of much else that hasn't been mentioned already.
I find the placement of the mizzen mast interesting though. Would be interested in knowing how it is supported. It looks as if it is directly over the engine. Is there a beam under it or some other sort of arrangement? I don't think you could put a compression post there.
I replaced my forward stanchions and bases on Argyle. I used the S3610 from Spartan Marine for the bases:
http://www.spartanmarine.com/c.....talog.html
There are several similar types around. There isn't room for proper backing plates on the inside of the bulwarks/caprail that covers all four bolts of the bases at the same time. I ended up using a steel backing plate through the two inboard bolts and nuts/washers for the two outboard bolts. One little trick I did to ease the installation was that I threaded the backing plate. I got 1/4" steel and had it cut to the correct small bar sizes. Then I just tapped 1/4-20 thread directly into the plate. This made installing these a lot easier, especially since once you got both machine screws started, you no longer needed a wrench held in an awkward spot below decks.
There is very little room inside to access the stanchion backing plates, if they are the type that are bolted to the caprail. But, there is just enough room to fit a hand an a wrench. Having an assistant with small hands helps here.
The gate stanchions are more complicated, so I just left in place after pulling them up and re-bedding. I don't remember if they have backing plates or just fender washers. Fender washers are not that bad in this application since the mounting bolts pass through about 1" of caprail teak and about 3/8" of solid fiberglass.
I am seriously thinking about changing out my stanchions and welding a solid top rail in from bow to stern. Maybe a fitting on the pulpit that allows the rail to be bolted to it there with a slight downward angle from the last forward stanchion to give the jib an easier time of running over it.. I just like the security of a solid rail. to hold onto and not having to worry about are my lines safe. the middle still be 1/4 or so uncovered stainless line.
