Bilge pump advice General Forum Forums
Bilge pump advice
April 8, 2014 - 2:01 am
I have a DE38 and would like to know what others have used as a manual bilge pump and where and how you mounted it?
I have a Whale Gusher Titan and would like advice on where to mount it.
thanks
April 8, 2014 - 9:42 am
not sure what model but it is a whale I believe and is mounted in the port forward side wall of the cockpit foot well. You pump it horizontally in a for and aft motion and the hose runs forward underneath the cockpit foot well floor and then down the forward engine bulkhead on the portside of the companionway and down to a scrum box in the bilge. discharge line runs aft against the bottom of the foot well floor and on to the transom where it goes out through a through hull above the water line.
May 11, 2014 - 1:31 pm
I've only had my boat about 9 months now, but I've noticed that I have about a half inch of water in the bilge. Pretty much all the time.
I just thought I'd put it out there to the group about standing water in the bilge and if this is normal or a big problem or what?
I am guessing that it's coming in slowly enough that evaporation is keeping it at this level. I've sponged it fairly dry and then over time it rises up, but never more than a half inch or so.
Thanks again.
May 11, 2014 - 9:52 pm
When we are using the boat it will typically have an inch or so of water in the bilge most of the time. If we are not using the engine though it will typically dry out and have no water in there. We don't have a small bilge pump that is flush down against the bilge floor so the bilge pumps don't pull it all out. Both the electric and the manual bilge pumps have big scrum boxes on them that leave an inch or two of water in the lower bilge under the engine after they start to suck air. I have wanted to but havent gotten around to yet pulling everything out of there and re-doing it as well as putting a third small bilge pump in that is the first to turn on when water is in the bilge and will pump it down to less than a 1/4 inch. Only if it can't keep up will the water level rise and the bigger pumps even come on.
Water that gets in the bilge comes from five major places on our boat.
1. Filling the water tanks the overflow/vent lines will spit water out in the bilge and one of the fill lines has a leak in it. It doesn't hurt anything but will put a few gallons of water in the bilge when we fill the tank. I have the new fill hose but haven't installed it yet.
2. Defrosting and cleaning the fridge will let water drain out of it into the bilge. This I don't like as it lets a little dirty water down there that could cause odors. I haven't done anything about it yet though. In reality we only defrost and clean it a couple times a year and the water isn't that nasty.
3. If the engine is running and prop shaft turning we get the small leak from the stuffing box that is the hall mark of a correctly working old school stuffing box. One day I will probably go to a drip-less style but till then I will live with it.
4. We have a weird leak on starboard that once in a while will put a few cups of water in the boat with a heavy rain. Not sure why or where it is but sometimes it doesn't leak and sometimes it does.. just weird but doesn't hurt anything where it is running through the boat. As we work on deck hardware we keep making sure to bed everything well and one day will probably find the leak and fix it without even knowing it was the leak. 🙂
5. Water coming in with the anchor chain or water over the bow or sometimes heavy rain would get into the chain locker and then drain through the boat to the bilges. We stopped this by installing a sump and bilge pump in the sump under the floor in the v-berth. We then ran a 1.5 inch hose from the lower anchor locker to the sump. The fitting that hose attaches to also totally seals the anchor lockers from the rest of the boat. This has left our upper bilges bone dusty dry most of the time for the last 4 years since we did it.
 Check all your through hulls and sea cocks to make sure there are no drips or leaks from any of them. Watch the bilges during a heavy rain to see if water is running down from the upper bilges to the lower one under the engine. Check your pressure water system and pump. At one time we had a drip from the pump in our system that was pretty steady. It would cause the pump to run every 15 to 20 minutes for a second or two on its own. That one is pretty obvious that something is wrong though as your pump is turning on while no one is using water 🙂
hope this helps a little. I think it is pretty comprehensive but to be honest my brain is pretty fried and I could be missing something 🙂
May 12, 2014 - 5:40 pm
I did defrost the fridge about a month ago and there was rain as well. I'm rebuilding the whale pump right now. It's intake is under the engine...which I guess is the lowest place in the bilge. I hurt my elbow using the sponge to try an get the last half inch out of the bilge. That thing hold a lot!!
May 12, 2014 - 9:56 pm
The bilge under the engine is the real bilge. The area forward and above that I call the upper bilge where the fuel and water tanks are. Yes the bilge under the engine can hold a lot of water. I would guess hundreds of gallons. Thats a lot of water to get out with a sponge 🙂 lol
September 10, 2014 - 7:48 pm
I just now pulled all the water out of there with one of those hand operated bilge pumps.  I think there was 5 inches of water and fuel mixed down there which the electric bilge pump could not get.  This is the one I used: http://goo.gl/8hDzLw  It had the lovely armoa of rotting diesel with just a hint of hot garbage water.
I was able to actually pump the bilge completely dry into a few 5 gallon buckets.  I don't think the deep sump under the engine holds hundreds of gallons.  The actual amount it holds is approximated in the manual somewhere where it talks about how the icebox drains into the bilge.  I believe it mentions that 10 - 15 gallons of water in there is enough to trip the automatic bilge pump.  Don't forget it gets really narrow near the stern and volumes can be deceptive.  I only know this because I've been trying to figure out if poly tanks that go under the engine are still a viable option.  Monday we start the demolition on the floor in the galley.
I also have one of the manually operated bilge pumps permanently mounted to the cockpit well in the same place Scott describes in the exact same configuration.  A green PEX tube goes down below the engine and the nasty is pumped overboard through a slop box.
On the subject of bilge pumps, how does one replace the main bilge pump?  Can that only be done by tiny robots?  Removing the fuel tank/engine?  I'm thinking while I have the boat ripped apart I may as well get in there and replace it 'cause god only knows how old that thing is.
September 10, 2014 - 8:00 pm
I don't have a bilge pump in the bilge.. just the hoses running from manual or diaphragm electric bilge pumps that are behind the batteries up high in the eninge compartment. I plan on adding a little small bilge pump on the end of the board that I have that holds the sensor/switch for the electric bilge pumps. They are pretty big, though not huge and leave an inch or so of water in the bilge. I think a real small one on the end of the board that can suck it almost perfectly dry with the big bilge pumps switch just above it or near the top of it beside it. So that they only come on if water gets past it.
September 10, 2014 - 9:03 pm
Mine's got a bilge pump directly beneath the fuel tank and I suspect it may be original.  I got a Y-Junction with dual check valves so I can finally rig up my secondary one which is mounted on a stick that dips down into the bilge.
Since my project on Monday involves tearing out the floors of the galley I was thinking of just redoing it while I have it all ripped apart.
September 10, 2014 - 9:25 pm
If its all going to be apart and easy access that is the time to do it...it no fun at all in the best of times to access that space.
