Universal diesel engines data Engines and Such Forums
September 13, 2013 - 9:47 pm
For those with Universal diesels.
This comes from the Catalina forum which uses Universal engines as well.
DE32 Oasis currently has the Universal 5424 (also known as M30).
Model number, horsepower, general info about Universal
MODEL
CUBIC INCH
HP
#CYLINDERS
WEIGHT
BLOCK MODEL
YEARS
QTY. SOLD
5411 (M15)
31
11
2
245
Z-500
77-82
2900
5416 (M20)
45
16
2
365
Z-751
76-82
1000
5421 (M25)
52
21
3
285
D-850
78-81
1000
5424 (M30)
68
24
3
425
D-1101
77-83
1050
5432 (M40)
91
32
4
490
V-1501
78-82
650
5444 (M50)
115
44
4
545
V-1902
80-82
280
M-12
24.4
10
2
175
Z-400
83-88
1200
M2-12
26
11
2
175
Z-430
87-90
320
M-15
31
11
2
245
Z-500
82-83
370
M-18
34.8
14
2
255
Z-600
83-88
2400
M-20
45
16
2
365
Z-751
82-83
230
M3-20(A)
38.9
18
3
235
D-640
88-
525
M-25
52
21
3
285
D-850
81-86
3650
M-25XP(A)
57
23
3
285
D-950
86-
3100
M-30
68
24
3
425
D-1101&1102
83-87
400
M4-30(A)
52
24
4
270
Y-850
88-
470
M-35
75.5
30
4
335
V-1200
87-
280
M-40
91
32
4
545
V-1502
82-
360
M-50(A)
115
44
4
545
V-1902
82-
520
M3-20B
43.8
20
3
241
M-25XPB
61.2
26
3
295
Information
M-35B
81.47
35
4
352
Not
M-40B
91.41
37.5
4
356
Complete
M-50B
113.32
42
4
529
These models have been discontinued.  Replacement models are in parenthesis
Mini series
(A)
These models have upgraded wiring harnesses
September 15, 2013 - 10:27 am
here is an engine info page that has a lot of Universal Engine info for our boats..
http://downeasteryachts.com/in…..ngine-info
The standard engine in the DE38 was the 5432 (M40) there is a lot of info on the page above about the M40 however we don't have a huge amount of info about the M30. If anyone has more info such as part numbers for filters and other common stuff as well as crossover number for common parts it would be great to add that to the engine info page.
September 19, 2013 - 12:58 am
For the Universal 5424 on Oasis:
I use the following engine-mounted spin-on Fuel Filter:   Universal 298854, I have only found it online.
I use the following engine-mounted oil filter:  WIX 51374 or NAPA 1374(no longer avail?) or Carquest 85374, available from auto parts store.
Oil:  5.0 to 5.5 Quarts.  I use Shell Rotella T1 straight grade heavy duty engine oil SAE 30 rated CF2,CF
The pump/impeller is  Oberdorfer 202M-07.  The impeller slides off the shaft after the front clip-ring is pinched & removed.  The impeller has one flat edge as a key for the shaft.
See http://www.pumpagents.com/Ober.....Pumps.html
I have a Hurth Transmission HBW-2R. It uses 0.55L transmission oil (1.3 pints).  I put in automatic transmission fluid Type "A", change every year or every 300 hrs.
Fresh water Radiator uses coolant 50/50 solution total 6 Quarts.  I have not changed it yet.
I don't think I have any info on the alternator.
Heat exchanger is (?) and uses a pencil zinc of (?)
