Vegetarian Hamburgers Cruising Corner Forums
January 18, 2011 - 1:00 pm
In the interest of trying new things with an eye to eating well on the boat I came up with a recipie for vegitarian hamburgers last night. They exceeded my wildest expectations.. Not only did it work but it worked great. We enjoyed the vegetarian burgers as much as a regular hamburger.  We made some home made bread to use for the burgers and simply put mustard, ketchup and letuce on them before eating them..
I can't say that I worked hard to perfect it. I just lucked out the first time out of the door. I had read 5 or 6 recipies for vegitarian burgers and decided on a whim to make them last night. Unfortuanately I didn't have all the ingredients for any of the recipies I had read.. So using a wee bit of judgement based on the other recipies and adding a few things that I thought would work well I came up with my own.
so without further ado here is the recipie I came up with..
Just a note: Though this is vegetarian it can't be considered vegan as there is one egg used in its making.
This recipe was enough to make 6 medium sized burgers.
The ingredients that I end up using this time were
1  ½ cups of oatmeal. I don't think they type of oatmeal matters. What I had on hand was some Quaker Oatmeal.
1 tablespoon of olive oil.. (this is just to sauté the ingredients in. )
1 small onion grated (had a good cry on this one)
4 or 5 cloves of garlic. I used a garlic press to process this but you could dice it up fine and then crush it with the flat of a knife blade also.
1/3 of a cup of grated carrot
1/3 of a cub of grated mushrooms ( I had never grated mushrooms before.. kinda weird. None of the recipes I read had mushrooms in them but I had them around and thought they would do well.
¼ cup of grated/shredded cheese. (the recipes I read used cheddar but I had some apple smoked cheese sitting around so I used that..Think very sharp cheese)
2 tablespoons yoshidas sauce. (The recipes I looked at called for 1 tablespoon of soy sauce. I normally used yoshidas sauce instead and did so here)
1 ½ cups all purpose flour. (I actually didn't use the flour because I forgot to when doing the burgers. I think it would be good to though.. I have to admit that they turned out great without it though.)
1 egg beaten (I used this as a binder. It is gooey and sticks everthing together for mixing and making the patties and then as the patties cook it acts as a glue there to. The finished patties that we ended up with after cooking could be picked up and handled without falling apart.
On a whim I mashed up a little less than a 1/4 cup of some left over carle's caribean black bean soup and threw it in also. /forums/cruising-corner/vegetarian-hamburgers/
1st after preparing all the ingredients (grating, pressing etc..) I sautéed the onions and garlic in a skillet on high… Maybe 2 or 3 minutes.. I had the skillet high enough that they started to brown a bit.. I then threw in the carrot, mushrooms, black bean soup and  cheese. I continued to cook all of it for another two or three minutes on high heat. I then threw in the oats and stirred it in for a minute or so.
I then dumped it all out into a big stainless mixing bowl.
I added a couple tablespoons of yoshidas sauce and the one egg that I had beaten with a fork in a small bowl. I then just stirred it all up. I added maybe a ¼ cup of water to moisten it just a bit more after stirring it for a minute or so. At this point I placed the mixture in the fridge for a while.. I'm not sure that this was necessary but one of the recipes I had looked at called for this.. I think it was merely to let the mixture thicken up a bit before forming it into patties.
I formed the patties by hand. Just grabbed a handful of mixture just like as if it had been hamburger and shaped it into a medium sized patty. The directions I read then took the patties and used the flour to bread them top and bottom, however I forgot to do that and cooked them without this step. I'm looking forward to doing it again after breading them.
You can cook the burgers in a skillet, on a grill or like I did with a george forman grill that cooks from the top and bottom at the same time. I found that with the george forman grill that it compressed the patties and browned them top and bottom at the same time. I'm not sure if it would give different results on a grill or skillet but I found that the patties after cooking for 10 to 15 minutes were very cohesive and not prone to fall apart.
We found the flavor to be really good and the texture was very burger like. This is going to be a regular on the menu from now on. It will be interesting as we try this again and play with the ingredients to see what we can come up with. I think I will add some spices next time… pepper, salt, maybe make a spicy version with a touch of hot pepper or maybe some mesquite flavoring..
timbalfour
January 18, 2011 - 5:02 pm
Forum Posts: 54
We do something similar, with TVP as well (soaked in a little hot water and Marmite first). For people who don't know TVP - it's basically dehydrated soya protien. Comes in small almost granulated form. Ends up like mince when re-hydrated. Also comes in various chunk forms, some flavoured, which are suprisingly like meat in texture. It's very cheap too.
The great thing about this stuff, is that it lasts forever on a boat and is the best vegetable protien source there is. We got a load of this in Panama before crossing the Pacific and only finished it about 5 years later! ( Note -  things like this are important when you've lived aboard in the tropics for many years without refrigeration, until our last boat and of course this one!)
Tim - 'Pelli'
January 18, 2011 - 6:22 pm
I am starting to try recipes and stuff that are healthy and boat friendly. Some have been successful such as the above recipe some have'nt 🙂
Almost everything we purchase now and a lot of the things we do are oriented toward can this fit on and will it work on the boat.
I would love to see some of the other members recipe's that have been out sailing 🙂
