Robertson screws Cruising Corner Forums
Robertson screws
April 5, 2011 - 5:36 pm
My boat is a mix of annoying screw types as typical of U.S. manufacturing.  Anytime I drop a screw or slip a driver I reconsider replacing every last one with these instead.
(wikipedia entry)
Screw Head - Robertson.svg
Close-up of a Robertson screw
A Robertson, also known as a square,[15] screw drive has a square-shaped
socket in the screw head and a square protrusion on the tool. Both the
tool and the socket have a taper to make inserting the tool easier.
Robertson screws are used mainly in Canada (where they are very common), though they can be found elsewhere.[16]
Robertson screwdrivers are easy to use one-handed, because the tapered
socket retains the screw, even if it is shaken. They also allow for the
use of angled screw drivers and trim head screws. The socket-headed
Robertson screws are self-centering, reduce cam out, stop a power tool
when set, and can be removed if painted-over or old and rusty. In
industry, they speed up production and reduce product damage.[17]
Canadian P.L. Robertson invented the Robertson screw and screwdriver in 1908 and received a patent in 1909. An earlier square drive wood screw patent, U.S. Patent 161,390, was issued to Allan Cummings on March 30, 1875.
Robertson had licensed the screw in England, but the party that he was dealing with intentionally drove the company into bankruptcy and purchased the rights from the trustee, thus circumventing Robertson.[citation needed]
He spent a small fortune buying back the rights. Subsequently, he
refused to allow anyone to make the screws under license. When Henry Ford tried out the Robertson screws he found they saved considerable time in Model T
production, but when Robertson refused to license the screws to Ford,
Ford realized that the supply of screws would not be guaranteed and
chose to limit their use in production to Ford's Canadian division.[18][19][20]
Robertson's refusal to license his screws prevented their widespread
adoption in the United States, where the more widely licensed Phillips
head has gained acceptance. The restriction of licensing of Robertson's
internal-wrenching square may have sped the development of the internal-wrenching hexagon, although documentation of this is limited.
Robertson-head screwdrivers are available in range of tip-sizes.  A given driver's suitability for use with a particular size of screw
and recess size is indicated upon its handle according to the following
color code:
Recess dimensions[21][22]
Colour Screw types Fraction Range
Orange (#00) No. 1 & 2 1/16 in.+ 1.77–1.80 mm (0.070–0.071 in)
Yellow (#0) No. 3 & 4 3/32 in.- 2.29–2.31 mm (0.090–0.091 in)
Green (#1) No. 5, 6 & 7 7/64 in.+ 2.82–2.86 mm (0.111–0.113 in)
Red (#2) No. 8, 9 & 10 1/8 in.+ 3.34–3.38 mm (0.131–0.133 in)
Black (#3) No. 12 and larger 3/16 in.+ 4.81–4.85 mm (0.189–0.191 in)
April 6, 2011 - 12:01 am
I think I'm going that route.  After taking the entire boat apart, wooden pieces included, I am sick and tired of the flat heads they used to hold this thing together.  Getting through each bung and having to deal with stripped heads ~50% of the time made it for a long process.
