Deck Paint Cruising Corner Forums
Deck Paint
Isabella
Matthews Point, NC
January 18, 2011 - 6:20 pm
Forum Posts: 36
I am curious, very curious about what has been used to paint the deck of your boat, how long it has last and the ease of the job at hand.  Our boat is about to leave Deaton's in Oriental and everything I mentioned to use to do the deck was [Image Can Not Be Found].  I know the process of what should be done first.  Any and all suggestions as always are appreciated.    Suzanne
Pete & Suzanne Evans
January 18, 2011 - 6:32 pm
This is something we are getting ready to do.. I had hoped to get it done this fall but that didn't happen. cheapest way would be to just paint it and sprinkle sand in the wet paint. Then once dry sweep off all excess sand. Paint once more and your done.. It is cheap and very very durable. The downside is that if you skid on it, you can plan on losing what ever skin came in contact with it. It's like sandpaper on steroids.. This is basically what was factory on these boats.
After looking at all the options our plan is to be adventurus and use one of the products that is a rubberized paint with rubber particles in it for texture. There are mixed reviews with it. A few people have reported issues with its adhesion.. Most say it sticks like sh&% 🙂 Also there have been reports of chemicals attacking it and discoloring it or making it soft. However application is supposed to be easy.. just paint it on in two applications.. If you have to touch up in the future you can just paint on a new layer over the old one. Supposedly it fuses to itself. Also it is supposed to be very gripy for traction both dry or wet and much esier on the skin. We have found a supplier that sells this type of material for a cost that we think we could do all the non skid on a DE38 for around $350.
However it is a milage may varry kinda thing... not a lot of track record... some great reviews and some medoicre ones and a few real hate it ones. we are willing to take the risk and try and will document and comment through and after the process.. Probably this spring or summer. 🙂
Isabella
Matthews Point, NC
January 18, 2011 - 7:50 pm
Forum Posts: 36
Sounds like an interesting direction to go.  I'd rather keep my skin so sand is not an option.  I'll research your choice a little further.    It may come down to when and the mood I'm in when I start this update.  Thanks Scott
January 18, 2011 - 8:31 pm
I am always willing to push the envolope and try new things if it isn't to cost prohibitive 🙂 I will have to dig out the paper work but I will try and find the lowest cost distributer of this stuff we found.
It looks like the same stuff that http://www.durabakcompany.com/ sells or http://www.grizzlygrip.com/
Durabak was about 120 bucks a gallon.
Grizzlygrip was about 80 bucks a gallon if I remember there was an upcharge for the uv additives maybe.
The vender we found is around  70 dollars a gallon if bought by the 5 gallon bucket....
all of them offer the product in different colors. we were plannin on a sand color.. light enough to not get to hot but with enough color to it to not show stains that bad if it does get some small ones. Not to mention that is the color of the existing non skid and it looks nice.
Isabella
Matthews Point, NC
January 18, 2011 - 8:37 pm
Forum Posts: 36
A little research.  Boatus did some comparisons.  Treadmaster Original looks like a wonderful direction to go if cost is not a factor.  Someone at Matthews Point had this and done right is beautiful. They gave one of the best ratings using Interlux Noskid added to Interlux Interdeck - if I read it correctly.. There are so many Interlux products that more research is in order.   I would love the combo of price, ease of going on and it lasting at least a couple years.
January 18, 2011 - 11:51 pm
paint with sand in it should last many years.. I think the interlux version should last many years.
Our non skid on valkyr is factory which is sand in a polyurethane paint? I believe is 30+ years old and still works as non skid very well.. it just has lots of nicks and cracks, stains and very large areas where we have ground the non skid away and fixed soft spots in the deck. Cosmetically it looks aweful.. like the boat has been through a war and lost 🙂 We are hoping the urethane paint will just cover the old non skid and fill in any chips or cracks and seal them. According to a couple of different vendors for this stuff it should bond like crazy to the old non skid and form a many mil thick rubbery surface that totally seals everything under it. I'm more worried about if we decide to take it off how to do that 🙂 probably chisels pulling up it and the old nonskid under it.
timbalfour
January 22, 2011 - 6:03 pm
Forum Posts: 54
Beware of Interlux's nonslip aditive - it's not 'grity' enough! - especially with a coat or two of paint. Petit's skidless compound #9900 is much better. I've used this with Devoe's 2 part polyurethane on several boats - it lasts forever.
Tim 'Pelli' - DE32
bearfootbandit
August 25, 2012 - 5:37 pm
Forum Posts: 5
Deck paint. Oh lawdy, deck paint. 🙂 We're currently redoing the paint on the entire deck of our 45', and its been a pain. I'm taking the nonskid down to gelcoat, and priming it before putting a new coat. I'm going to use regular deck enamel and sand. The only reason I'm stripping it off is because of all the dings and worn out spots in it- if I just paint over it it will still show right through. We're crossing the gulf to get to the panama canal, and then across the ocean to hawaii so tough (and pretty) non skid is a must!
August 27, 2018 - 8:39 am
So just an update. We went with the rubbery truck bed liner type deck paint with some rubber aggregate in it to give it a coarse texture. 7 years later and it is holding up very well. It is very grippy and a bit giving. you don't lose skin to it. Over all it is a win for us. Only downside is that if you don't scrub the decks for a while and it gets that grey grimey mildewy effect going on it is really hard to clean. Only thing we have found to work is scrubbing with a very strong clorox solution. That fixes it right up though. Simple green worked to a degree but the clorox is what did the trick.  I have to say though that it was 4 years of deck neglect sitting in the slip that got it to that state. Under normal use just the normal soap and brush would work fine.
for pure utility and comfort this stuff rocks. I'm going to give it a very minor negative for slightly harder cleaning due to texture. It also looks really nice. Also it protects the underlying deck better than any other paint out there. drop something on deck and it just absorbs the impact no harm no foul. A sharp object might penetrate it but would limit the damage a lot compared to other paints.
I'm trying to think of name of company down in Florida I got it from but having no luck right now. have a old pail of it on the boat and will look at that next time I'm on her.
Capt. Nate
South Florida
January 30, 2019 - 7:14 pm
Forum Posts: 6
Scott,
Wondering if you ever came up with the name of the product you used to paint your deck and the distributor here in FL? Sounds like you applied over top of your old nonskid without completely sanding it down. That is exactly what I need to repaint my deck. Also have searched the site for any information on the deck material under the mast on the DE 32. Looks like I need to take my mast down and replace under. Life in the boat yard haha. Look forward to any info on the deck paint.
February 9, 2019 - 8:51 pm
I've been looking for this and finally dug it up.. this is what I used and other than one thing I love it. It seems really durable.. one downside is that it is hard to scrub sometimes because of the aggressive texture. One of the things I really like is the soft sort of aggressive texture. For non skid and livability its a definite winner. I put the link in for the 5 gallon pail.. you can get it in 1 gallon and for a few dollars more they now offer color matching for colors outside their standard ones.
https://www.acrytech.com/product/soft-tread-anti-slip-coating-standard-colors-5-gallons/
Capt. Nate
South Florida
February 12, 2019 - 11:15 pm
Forum Posts: 6
This sounds good. i think i will get it a try. Thanks for digging that up. Can you remember how much it took to cover your 38? One coat or two? Sounds like what i have been looking for and at an affordable price. Will be awhile before i will have a chance to apply the paint but will post the results.
February 13, 2019 - 1:19 pm
5 gallon bucket did the whole deck and forward coach roof but not the aft coach roof. I think 6 gallons would guaranteed full coverage with a couple coats of all nonskid on the boat.
also about not sanding all the non skid off.... yes.. I just scuffed the old non skid with 36 grit if I remember right and just went over the top of it. I think I washed deck before painting and after scuffing with TSP really good to make sure there were no oils etc that could affect the bond. So far in more than 5 years I have found maybe a couple places of a centimeter or so that have pulled up at a edge. Don't know why but other than that it is not coming off without being physically abraded off. I have dropped all kind of heavy stuff on it and dragged stuff over it etc.. it is very tough. I haven't touched any area up yet but supposedly I can just get a can and after a good cleaning just go right over the top of the original layer from what I can remember.
February 20, 2019 - 11:11 am
Lol.. I answered the recent questions without going back and reading the whole thread.. Had forgotten how long ago it had been. This stuff is tough and the most comfortable grippy surface I have ever felt on a boat deck. I forgot to mention that the observations others had made about it covering over cracked and worn existing nonskid was totally correct. It bonds to and seals everything under it. Just make sure it has some mechanical bite to adhere to such as a sanded surface and that it is cleaned. We sanded and scrubbed a couple times with TSP (TriSodiumPhosphate) in a strong solution to make sure there were no oils on deck to affect adhesion. Also now with the rubbery texture we don't get cracks or chips when stuff drops and hits the deck.
it really grimes up over time and is hard to clean once the mildew gets a hold. A pressure washer wont get it clean on its own. Normal soap won't touch it. Simple green and purple stuff cleaner and or vinegar did some but didn't leave it new clean, it still had mildew staining shadows everywhere. We used home depot extra strong industrial clorox and just sprayed it straight onto the deck at full concentration and then misted water over that and used a stiff brush to scrub the shit out of it. Let it sit for 15, 20 or more minutes keeping it wet with a mist  of water if it looked like it would dry out, scrubbed again and rinsed. Looked like new. It was vicious on us using that strong a concentration of clorox/bleach. I recommend a day windy enough to carry fumes away 🙂 or wear a mask that can handle them. We were worried that the chemicals would damage the coating or affect it negatively but it doesn't seem to have affected it at all.
Leo Uhran
Port St Lucie Fla
April 2, 2019 - 1:48 pm
Forum Posts: 42
I'm about to re-apply nonskid on Paper Moon. The previous owner who has done the entire restoration and refit of this boat instructed me to use Awl grip (Cream, same color as hull) Prep (sand) the existing surface to give it a bite, Tape off, roll on the Awl Grip and sprinkle "Soft Sand" (this is the rubberized granules) You can choose from 3 sizes, Fine, Medium, large in different colors. I'm going to use the white in Fine. You can find the supplier on the internet. Then, after it dries, sweep clean and re-apply a second coat of the Awl Grip over the top. The Awl grip does not need the two part mixing, just the paint itself. The previous owner worked for Hinkley Yachts for over 10 years, I'm going to follow his instructions, He's seemed to have done an outstanding job on the rest of the boat.
I tried getting him to finish the non-skid before he sold it but he didn't. It's the last thing left on the outer topsides that wasn't re-finished.
A note on the "Soft Sand" product, after viewing several You-Tube video's; Some of the comments were the larger granules seem to want to hold mildew and was difficult to keep clean. If applied heavily the resulting finish almost looks like a mat. I don't want that appearance so I'm choosing the Fine and not planning on over applying it. Once I finish off the topside I'll post photo's.
Leo
SV Paper Moon
Port St Lucie Fla
April 10, 2019 - 12:45 pm
Yep... the very rough texture does encourage mildew if you leave the boat unattended for long. Months not days or weeks. However I would never do the paint with sand in it I have bleed on to many boat decks over the years while kneeling or moving around and leaving my top layer of skin on my knees, elbows, hands etc.. when falling or rubbing on it. The rubberized paint and particles I used have great grip but don't tear the skin. It even feels softer to sit on. I wouldn't go back having tried it, even with the slightly higher cleaning work. If you only use your boat once in a while I can see doing the paint and sand with a low profile sand papery texture. To live aboard or use a lot the comfort of the rubberized product is great.
Leo Uhran
Port St Lucie Fla
April 11, 2019 - 8:49 am
Forum Posts: 42
Scott,
I'll post photo's when this is all done. Just completed the Awlgrip Oyster White finish in the cockpit, last bit not done by the previous owner, ordered the soft sand should be here today.
Another little project I've decided to do topside as part of the (my) finishing is add back one set of 4 rung teak handrails just over the V-Berth cabin portion only, (interior has headliner  removed and is painted, good time to do it while exposed, before another finishing project to match the saloon ceiling that has already been redone in wood)
Previous owner only left the aft section rails on the upper raised deck portion and removed, epoxied, fared and finished everything else. So, .. now I have to install these suckers. I'll have a local shop drill and c'bore from the rail top for 1/4-20 thru bolting, I will install a bung to seal the c'bore holes.
Here's the question. Can I just drill thru the cabin top and seal the rails with 4200 or do I have to epoxy encapsulate between the inner and outer decks. This is the "professional method" but does it really have to be done that way? The original installation didn't do that.
Also commissioning a set of companion way doors to be made, in preparation of A/C installation. I hate weather boards.
Leo, SV Paper Moon
Port St Lucie Fla
April 11, 2019 - 4:25 pm
I made companion way boards out of 1/2 inch acrylic. I have been doing that to all my boats the last .. wow.. 20 years. It makes a huge difference in light below and able to see out on rainy/cold/snow/hot ac days. It is one of my go to live aboard projects along with fans, lots of led lights, screens on hatches and waterproof fabric wind scoops for hatches to catch air or suck air out of the boat and then last but not least canvas/sunbrella/tarp etc sunshades/awnings for over coach roof on exposed deck. Sometimes cover the whole deck 5ft or more high with the ability to clip one side lower. It is more problematic with that large a piece of fabric shading the boat if the wind picks up while anchored but other than that it is the bomb for cool and even dry. I recommend the color white  especially the further south your boat is.
I will let you know my rule for core.. 100% seal and encapsulate any penetrations whether they go through half way or all the way. There are actually two reasons both with lots of value.
1st ......is that no matter how well you seal it eventually in a year or 20 years you will get water into the core and then have to fix de-lamination. Once water gets in, the first sunny day it turns to vapor that penetrates large areas and you can never dry it totally without pulling it apart. Moisture in there is long term problems. with the foam core in the DE's it takes years and years compared to wood but Eventually you have issues. I would be surprised to see a DE that hasn't had this issue in one degree or another. Our boat is solid but it has had parts of the cockpit re-cored, a little place on a side deck and another larger area in the bow. It's not a job outside anyone's capabilities to do but it is a bit of labor. Pretty much any boat brand of that era has the same issues if it is cored. Deck coring wouldn't slow me down on owning an old boat, coring of the hull and I would not only walk away but run from owning a boat old or new. I consider every project that pulls old hard ware off a opportunity to upgrade that part of the boat. To make my life easy when doing this I just buy the premixed calking tubes of west systems thickened epoxy at west marine or better yet at lowe's hardware if they carry it there. Last time a few years ago that I purchased it, it cost 10 dollars or so a tube at lowes and 15ish at west marine. It's a really clean lack of labor way to do small projects like that when your replacing rails, or pulling and replacing winches or whatever the hardware is.
2nd....   leaks that get into the core usually don't come out inside the boat at the bottom of the penetration into the overhead. They go down and then run through the core and build up water or find an exit point for or aft of the ingress point. So  you might know you have a leak but not know where it is, You seal where it is coming in and that just forces more water to live in the core without leaking out anymore or until it finds another place to drip out. If you seal and core and then have a leak there you know that that is where the leak is period.
When working on coring and filling holes, I like to use Allen wrenches. I always have a plethora of them in my tool box from all the electronics that ship with them to open battery compartments or other adjustments on thing so it's easy just to grab one and put it in a chuck on a drill and use it to wallow out the foam core after opening the hole 1/8 to 1/4 inch larger diameter than the hole you need for your fastener. once wallowed out I tape the bottom and inject the epoxy, use the allen key by hand to make sure any bubbles or air pockets get pulled out of the wallowed out area. Fill till it domes up a little and let it cure. next day I might cut the domed up area off flush if it hasn't shrunk down level or concave. Then if it's hard enough drill it back out.
After the second time of chasing leaks I couldn't find due to this issue, and the first time with a soft spot that needed to be re cored I became a convert to just doing it right. If you have to money to pay someone else to fix then it probably won't bother you much other than your pocket book but having to do it myself its one of those things I don't ever want to do again.
off topic
I have a similar pet peeve with marine heads. I will never have one on a boat I own again. First project is put a composting head in. After twice fixing the flapper valve on a marine toilet and twice cleaning up after a leak or overflow out of a holding tank in to a boat I decided I never ever wanted to do it again. 🙂 turned out great as composting heads don't have odor like a toilet/holding tank does so once changed over the boat never has that odor and I have never had to repair the toilet/septic system again. No pump outs, recovered all the space where holding tank was for storage. Dropped weight by amount of full tank, plumbing and toilet. Commercial composting heads only weight a few lbs.
8 Guest(s)
Today Treenut
