Windlass, Chain Type and Size for DE38? Cruising Corner Forums
May 10, 2016 - 10:52 pm
Forum Posts: 128
Another item high on my to-do list is to add a windlass and probably a new lot of chain.  The 45lb CQR anchor that came with the boat should be fine, but the rode of (maybe) 50' of 5/16" chain and (maybe) 100 ft of line is surely undersized.
Looking at windlasses I am thinking I need 1000 lb max pull based on the formula of 4 x the weight of the anchor and chain. So, a 45 lb anchor plus 200 ft of chain would fit.  Some people say that 3 x is enough.  Any comments?
For the windlass, the Lofrans Cayman seems to fit the bill at around $2 grand.  Lewmar have cheaper units, but I hear they are not reliable.
As to chain I know nothing about BBB vs HT or size.  5/16" seems to be about right, but don't have any real basis for this.
So again, I open the discussion to my learned co-owners.
Many thanks in advance.
CryWink
KachemakRa
Homer, Alaska
May 18, 2016 - 2:06 am
Forum Posts: 30
Dolphin, DE 32, I added a Lewmar Pro Series (fishing-type) windlass. It works fine, Does not have the versatility of a duel horizontal, but OK and affordable.
The challenge I have is with the chain, even the rope, feeding itself down into the chain locker beneath the V-berth bunks. Therefore, I have to remove all bedding, take-off at least one, if not both cushions, as I pull anchor. Clearly not an optimum situation.
Does anyone have a solution?
May 18, 2016 - 12:00 pm
Forum Posts: 128
Thanks for that tip.  Lewmar windlass looks fine and are, as you say, much less $$ than, for example, Lofrans.
Solutions to chain pileup are not pretty or simple.  Tubing of some sort leads the chain to the space under the V berth.  Seems to be a two man job to stow the chain when raising the anchor.
Yesterday, I examined my layout more carefully and found another "chain" locker just aft of the main locker under the very front of the V berth.  In my case the rope line ends up there.  If I went to all chain, and made a larger hole between the two lockers I could have chain falling down there pretty easily.
Strange thing, though that this second chain locker does not drain into the main bilge.  Of course I can drill a large hole to open it up.  Just curious to know if this is standard, or if there was a hole there originally that has been plugged up over the years.
Fun to sort out!!!Wink
May 25, 2016 - 8:38 am
Forum Posts: 1388
you do not want it draining to main bilge. this leaves muck and odor the length of the boat. Stuff builds up on and under the water tanks and fuel tank that lead to corrosion. Mine was like that and we put a forward bilge box and lead a hose from that chain locker to the bilge box just under the v berth cabin sole. The shower, bilges and AC system condensate line all lead there and pump overboard close to deck level behind the full length closet on starboard. Bilge is mostly bone dry since we did that.
May 25, 2016 - 8:08 pm
Forum Posts: 128
OK, Scott. That makes good sense and boosts the credibility of the boat maker.
I will keep that locker isolated and just clean it out now and then.
Cheers
May 26, 2016 - 9:15 am
Forum Posts: 1388
lol... I'm not sure I would leave it isolated. In bad seas you will take water over the bow and a fair amount of water will get in the chain locker. We normally get a bit in there in heavy rains also. You need a mechanism to remove that water. Someone had already hacked a hole connecting that to the rest of the boat on mine so I did that forward bilge box. If you don't do something similar I would put a bilge pump in the lowest part of that lower chain locker pumping back overboard. Make sure you put a one way valve in it as you can take water on through the through hull if you put it on the deck or side of boat up near the bow.
June 1, 2016 - 3:27 am
Forum Posts: 128
Scott.
i just meant to follow your advice not to let water from lower chain locker to main bilge. I can see that one needs a way to get accumulated water out. Some boats have a drain hole in the bottom of the chain locker going straight overboard.
back to the drawing board!
bob
June 6, 2016 - 8:17 am
Forum Posts: 1388
Only problem with hole in chain locker is that the bottom of our chain lockers is below the waterline :)
Wundor Star
June 10, 2016 - 8:42 pm
Forum Posts: 22
Bob, on WundorStar we put the tigress windlass, which we got a smokin deal from Manneys Boat supply. The owner has a DE38, so a lot of the stuff they sell fit rather nicely. I fabed up a platform for it to sit above the bowsprit, with a hawse tube (might be wrong term) for the chain to feed into locker. The tube reduces the egress of water greatly. We run 300' of 5/16. I carry a centinal also. System seems to be working good.  Only wish our style boat had better access to the locker from the deck. Chain pile is the only problem to date. Recommend the bigger windlass though, over the smaller Lofrans. Good Luck Travis
Travis and Kim
S/V WundorStar
DE 38 Ketch
June 13, 2016 - 3:09 pm
Forum Posts: 92
Did you mean Minney's boat supply in Ca?
June 19, 2016 - 7:31 am
Forum Posts: 128
Rick.  I am sure Travis meant Minneys.  I'll check out their offerings for winches.  I did buy some nice Lewmar sheet winches from them at half price!
Travis.  Tigres does seem the weapon of choice here.  Thanks for the tip.  Curious why you need a platform above the bowsprit.  Does it not fit onto the bowsprit itself?
How do you cope with the chain piling up?
Thanks to all.
June 20, 2016 - 11:30 am
Forum Posts: 128
Travis
I took a closer look at my bowsprit and see that a Tigres won't fit there easily due to the inner forestay connection, so your platform does make sense.  If you have a photo of it that would be nice. I'll have to look at other windlasses, too.  I know one can be put aft of the bowsprit but then the chain would go right into the forepeak cabin.
Always something...
June 20, 2016 - 8:26 pm
Forum Posts: 128
Travis
I just checked with Minney's and they still have the Tigres windlass.  I'll call them in the morning.
Looking more closely at what it takes I can see that you need the "platform" on top of the bowsprit.
A photo or sketch of your setup would be most helpful.
Other windlasses of similar power seem to be pretty similar in size so the Tigres maybe the one to get.
Thanks in advance.
Confused
August 26, 2016 - 12:16 am
Forum Posts: 40
Have had various anchor rode combinations over the 37 years we have owned our DE 38.  We have settled with  200 ft of 3/8  BBB chain that fits our gypsy on a Lofrans Tiger windlass.  The windlass fits on a one inch thick piece of wood on top of the  bowsprit.  The hose pipe is large enough to fit  the winch handle down it to knock down the chain pile up, to save a few trips running down below.  We have a salt water pressure pump attached to the toilet inlet to keep the chain clean.  Have taken this same line and run it to the cockpit for salt water showers and wash down.  The windlass has one O welding cable from a battery below the settee in the bow.  This gives us all the power we need to the windlass, and has been trouble free for 31 years.  We did change the foot switch to a Ideal foot switch which has been trouble free.  We do have the chain secured to the hull by 80 feet of 1/2 inch line.  When on a passage we put the 45 lb CQR down below and put a plug in the hose pipe.  When at anchor I have made a plug for the hose pipe that has a slot in it for the chain   Hope this helps.
April 29, 2017 - 6:30 pm
Forum Posts: 128
Thanks, Jim, for those good tips.  Sorry for the obviously slow response time, but have been working on other things this past year, notably renewing the instruments.
The Tigres is a great windlass and will probably be my choice, but the Lewmar Pro Series 1000 is tempting due to lower cost.  My immediate needs are for day sailing and occasional overnight so chain plus line should be sufficient although the added security of all chain like you have is undoubtedly the best option in the long run.
Decisions...decisions.
Cheers
Wink
May 9, 2017 - 11:56 am
Forum Posts: 128
Hi again.
Still debating on which windlass to get.  Like the Tigres but looks its too big for mounting on the bowsprit.  Could mount on the foredeck aft of the bowsprit, but rather in the way and messes up the forepeak berth.
Now thinking about a vertical windlass just aft of the chain locker.  Could enclose the motor to make it look better.  Anyone out there using a vertical windlass?  If so which make/model?  Have spotted the Anchorlift line which looks nice, but have not found anything about their quality, etc.  Any comments there?
Thanks in advance
Confused
May 13, 2017 - 3:24 pm
Forum Posts: 40
Have included a few pictures of our 30 yr old Tiger windlass.  No problems yet.  Motor is a Bosh starter motor which requires a lot of power if my memory serves.  Requires single O wire for a short run.  Moved stay sail boom forward and raised about 6 inches.  One inch wood base for windlass is thru bolted to deck.  Once had two of three strands of 3/4 inch nylon cut by one lone rock on sandy bottom.  Lesson learned1-DSCF1289.JPGImage Enlarger
2-DSCF1287.JPGImage Enlarger
to always dive your anchor or switch to all chain.
Cheers and beers
Save
May 14, 2017 - 4:37 pm
Forum Posts: 128
Thanks  very much, Jim. Very clear explanation and great photos.
I'm not too keen on moving the inner forestay, but judging from your image it's not really a huge issue.
I like your comment on having only chain rode.  I have been thinking of a mixed rode but maybe I'll have to reconsider that.
Fair winds
Smile
May 15, 2017 - 1:04 pm
Forum Posts: 40
Hi Bob,
A picture is worth a thousand words.   If you do get a Tiger windlass, do not get the white one.  The coating will eventually crack from the sun and the water will get underneath the coating and corrode the aluminum.  Also the chain stripper is held on to the windlass by two stainless bolts.  The dissimilar metals will cause corrosion and create a big problem.  I would suggest swapping them out to nylon or aluminum bolts.  If memory serves, there is an O ring between the motor case and gear box.  I added silicone at this joint to keep out water.
November 26, 2017 - 1:29 am
Forum Posts: 128
Well I finally found the windlass that seems to do the trick for me.  It's a Lewmar H3 model I found on eBay.  Will fit on top of the bowsprit but needs a special bracket to hold it down unless I can drill down through both the bowsprit beam and the deck below.
Now, and my reason for this post, I have to get the electrical work done and the first question is whether to have a dedicated battery in the forepeak or run the large cables from the engine room to the windlass.  With a 1000 watt motor with 110 amp circuit breaker I think the sensible choice will be the separate battery.  But what type and size battery, and how does one determine the size of the wire from the charger/alternator to the battery.  Any help and examples will be greatly appreciated.
Fair winds
January 15, 2018 - 8:09 am
Forum Posts: 1388
The manufacturer of the windless tech support should be able to give you a good idea what works will with that unit. I would probably bump the battery and wire one size from their recommendation as they usually do the minimum needed and I always like a little better than that.
November 10, 2018 - 12:06 pm
Forum Posts: 128
I hate to admit that I started this thread over 2 years ago and still have not finished the windlass installation!  But I am getting very close!
My latest question is more general about anchoring a DE38. I have a 45 lb CQR anchor, with chain and rope which are fed through the bowsprit about 24 in from the end. This means that the chain rubs on the bobstay when at anchor.  For my modest cruising around SF Bay that may not be a big problem, but I question that arrangement in general.
The obvious solution would be to add a bow roller at the very end of the bowsprit gut that would  add a big chunck of steel which would make a nice battering ram.  Not to popular around the marina or anchorage.
So I raise the issue here.  Do most of you just live with the rode rubbing on the bobstay or has anyone devised a protective covering to at least minimize the chafing?
Thanks in advance.  I'll get some photos up when its all done.Embarassed
andrewb
Geelong, Australia
November 11, 2018 - 3:48 am
Forum Posts: 7
I'd be interested in the answer to this one too. I read somewhere about a similar boat with a bowsprit & they attached the anchor via a chainstopper, or something similar, to the fitting at the bottom of the bobstay. The reason for doing this was to reduce the force of the chain as attaching it at or around the waterline meant it travelled through a smaller arc as the boat pitched. Seemed to make sense, but I haven't had the courage to attach the anchor to that point in case it isn't up to the job, though I see that my boat originally had a fairly large piece of rope attached to that point which may have been for that purpose (http://downeasteryachts.com/wp.....50x410.jpg - unfortunately the figurehead was not present by the time we took ownership , fell off somewhere mid-Pacific!)
November 12, 2018 - 7:03 am
Forum Posts: 40
Had the same problem as you while sleeping at night, especially in light winds.  The sound of the anchor rode sliding over the bob stay and it’s turnbuckle drove me crazy.  I solved this problem, somewhat, by using some PVC pipe.  Check out the picture I posted on this thread.
As far as attaching a line to the bob stay chainplate, l would not recommend it.  Have seen rust where the fiberglass meets the steel and this area cannot be inspected very well as the chainplate is inbeted in the  laminate.  I then added two external chainplates to beef up this area.
Hope this helps,
November 14, 2018 - 11:26 am
Forum Posts: 128
Thanks, Jim.
I did see your photo (after I raised the question) and plan to follow your lead with a bit of PVC pipe over the bob stay.  It will stop chafing and reduce noise.  Maybe other measures are needed for strong winds.
Cheers
BobSmile
Most Users Ever Online: 42
Jonathan Oasis: 161
bobmcd625: 128
Rick: 92
Erick: 83
Members: 289
Topics: 640
luketw77, deja vu, Tim Donley, Capt. Nate, BoatSalacia, DionSlowRide
Moderators: Patrick Twohig: 125
Administrators: Scott Carle: 1388
